I am using the generic label tool and also find the lack of text wrap a problem. Please add that feature GS.
However the way the label tool works generally needs a bit of an overhaul for a few reasons:
If you are automatically labelling different element types, you have to set up the label for each, but then if you save it as a favourite, the additional tags set up is not saved in that favourite
The only way to get access to the sorted version of the additional tags is firstly to pick show all, then pick sorting. The sorting function does not work first time.
It would also be good to avoid the need to set up the additional tags options in both menus as you have to now; firstly in the symbol label options, then in the additional tags options
This is potentially a really powerful tool and I hope GS will give this high prioiitry
	Tim Ball
AC26, iMac
User since V5
