4 weeks ago - last edited 4 weeks ago
Hi everyone,
I’m trying to create a schedule for some construction elements that I want to present on my layouts (mainly structural elements like beams/coloums).
I’ve set up custom properties to define these elements, and the schedule is supposed to read from those properties.
However, I’m getting an extra “ghost” row in the schedule that I can’t seem to remove.
There is only one element in the model, and when I delete that beam, the “ghost” row disappears as well — so it seems to be related to that same element.
I’ve attached screenshots.
Has anyone experienced something similar, or knows what might be causing this?
Thanks in advance!
Solved! Go to Solution.
4 weeks ago
Keep in mind that from the moment segments in Beams and Columns were introduced Archicad clculates them in Schedules.
It is possible that your Schedule is listing a segment of that beam as a separate element. Use Criteria to exclude Beam segments from the schedule an see what happens.
4 weeks ago
4 weeks ago
Aha, thx LucaP - that was correct.
