2006-11-19
10:11 PM
- last edited on
2023-05-30
01:53 PM
by
Rubia Torres
2006-11-20 12:09 AM
2006-11-20 06:24 PM
2006-11-20 11:26 PM
2006-11-20 11:36 PM
2006-11-20 11:43 PM
TomWaltz wrote:Well, I jumped 8.
I used to see this all the time in Archicad 8.0..
2006-11-21 02:24 AM
2006-11-21 01:52 PM
Jeffe' wrote:If you have an earlier backed up version of the Project File, you can go to its Section in question, and copy-paste those lost data to your current Projet File. This could save most of the data.
WOW - this is REALLY getting bad. I have re-drawn all of my 2D stuff, set all the Section/Elevation settings to "Drawing" and Saved. Also Saved-As a new name.
Tried to Publish a set of .DWG's - looked at the files - some have the correct drawings in the viewpoerts, others have NOTHING.
Go back to the view in the Navigator and there is NOTHING THERE! Even the model is GONE! Nothing left but the stupid upside-down grid lines.
Re-opened the saved file and looked at the views - everything is OK.
Tried to Save-As a .DWG from the Layout. Opened in Acad, and the same thing happens - go back to the view and its gone. have to "rebuild from model" and it comes back, but all 2D is missing.
This is a HUGE bug. I will send this file to my Re-Seller to see if they can re-create it.
I will try this on one of the PC's and see if it does the same thing.
UPDATE 1: Save-As from an individual Section View to a DWG works fine.
UPDATE 2: Confirmed - Does the same thing on the PC.
Note - this occurs to the SAME sections on a particular layout. IE: If there are 4 different sections views on a sheet, it will always happen to the same ones.
AC build 1010 USA Full on both PC & Intel Imac.
