MAKE PUBLISHER EASIER TO USE
I HATE ARCHICAD WHEN IT COMES TO TRYING TO PUBLISH/PRINT/PRODUCE ANYHTHING. ITS SUCH A PAIN IN THE ASS TO HAVE TO NAVIGATE THROUGH 10 WINDOWS AND 4 DIFFRENT MENU SYSTEMS JUST TO GET A DAMN FILE TO PRINT. ITS BULLSHIT AND IT FUCKING SUCKS.
18 Replies 18
Many people feel the same way about reading posts that are in all caps.
Richard
AC26 (since AC6.0), Win10
gee thanks for your really helpful response. im so glad youve now solved all my problems.
dont reply if youve got nothing useful to say.
TomWaltz
slothdog wrote:
I HATE ARCHICAD WHEN IT COMES TO TRYING TO PUBLISH/PRINT/PRODUCE ANYHTHING. ITS SUCH A PAIN IN THE ASS TO HAVE TO NAVIGATE THROUGH 10 WINDOWS AND 4 DIFFRENT MENU SYSTEMS JUST TO GET A <b>[censored]</b> FILE TO PRINT. ITS <b>[censored]</b> AND IT <b>[censored]</b> SUCKS.
Really? I find it's pretty easy to use.
What problems are you having? Perhaps putting that energy into an intelligent question would help....
If all you want is to print, may I suggest the "Print" command?
Tom Waltz
TomWaltz
slothdog wrote:
[dont reply if youve got nothing useful to say.
Good advice. You should try it some time.
Tom Waltz
Dwight
Drinker.
Dwight Atkinson
I find publisher reasonably easy to use. Granted, there are tabs you need to check every time for file format and saved location etc, that would make sense to be together, and sometimes the translators don't quite give you the results you expect (or maybe I don't expect the results I get?), but that's Archicad, and that's why we love it.
Dwight
And it certainly is an improvement from before.
As with all Archicad functions, they require rigorous management and lack certain obvious presets.
Until ready to observe these contraints, revert to simple views, marquees and title block objects for simplified view management.
I use the simple method since I rarely publish more than three or four drawings/views at once.
Dwight Atkinson
TomWaltz
I'm on the opposite extreme. I routinely send out 35 PDFs at a time or 12 DWG files. Spending 15 minutes setting up a Publisher Set for each pays off big time!
Tom Waltz
The biggerst problem is that you cannot select multiple pages to give the same properties too. Sucks having to set each page up individually in a 35 page document only to find out when you print you missed one.
