2006-11-14
05:15 PM
- last edited on
2023-05-30
01:44 PM
by
Rubia Torres
2006-11-14 09:54 PM
Jeffe' wrote:You can't? Why not? I do it all the time.
The biggerst problem is that you cannot select multiple pages to give the same properties too. Sucks having to set each page up individually in a 35 page document only to find out when you print you missed one.
2006-11-14 10:02 PM
Jeffe' wrote:Jeffe' -- you need to create a "master folder" within the Publishing Set and place your "pages" in it -- then you only have to set the properties of the master folder and all included "pages" will be in sync.
2006-11-14 11:19 PM
Laura wrote:Indeed, it actually only needs one item in it before the format can be set. Hopefully this will be eliminated in the future, so that we can set the format of a completely empty folder.Jeffe' wrote:Jeffe' -- you need to create a "master folder" within the Publishing Set and place your "pages" in it -- then you only have to set the properties of the master folder and all included "pages" will be in sync.
2006-11-19 10:01 PM
2006-11-21 05:53 PM
Jeffe' wrote:Seems is the key word
Thanks all. Makeing a folder in the publisher set works like it is supposed to. Just another step that seems unecessary.
2006-11-27 07:00 PM
2006-11-29 05:13 AM
konnos wrote:Frankly, saving to PLT is not a good idea at all - because the PLT format is a historical thing, a remnant from the actual pen plotter era, now good 10 years behind us.
Archicad 9 was a pain in the ass to print correctly (saving into .plt) and until I finally got the hang of it. Then I upgraded to v10 only, to my horror, find out they ve changed the procedure. I haven't needed to use the Plot command yet, thank God, but I will be soon. And I hope it makes sense this time or you might read some censoring from me too to steam off.
2006-11-29 10:58 AM
2006-12-01 06:02 AM
konnos wrote:The obvious answer is PDF. However, that depends on whether your local shop wants to do it or not.
The reason I'm using .plt is because I send my drawings to a photocopy shop. If you know of a better way perhaps you can let me know. It's fine once you know what you need to be doing with a little experimenting.
konnos wrote:The Bug Report starts and you fill it up and send it, right? Plus, you email your tech support with the ID of the Bug Report?
The bad thing is that I can't even get a preview print from my A4 laser (Kyosera FS-1010). Even selecting the printer from inside AC10 (or v9 for the matter) crashes ArchiCad instantly and sends me to the desktop. Can't be bothered to look into it.
