MAKE PUBLISHER EASIER TO USE
I HATE ARCHICAD WHEN IT COMES TO TRYING TO PUBLISH/PRINT/PRODUCE ANYHTHING. ITS SUCH A PAIN IN THE ASS TO HAVE TO NAVIGATE THROUGH 10 WINDOWS AND 4 DIFFRENT MENU SYSTEMS JUST TO GET A DAMN FILE TO PRINT. ITS BULLSHIT AND IT FUCKING SUCKS.
18 REPLIES 18
TomWaltz
Jeffe' wrote:
The biggerst problem is that you cannot select multiple pages to give the same properties too. Sucks having to set each page up individually in a 35 page document only to find out when you print you missed one.
You can't? Why not? I do it all the time.
Tom Waltz
Laura Yanoviak
Jeffe' -- you need to create a "master folder" within the Publishing Set and place your "pages" in it -- then you only have to set the properties of the master folder and all included "pages" will be in sync.
Link
Indeed, it actually only needs one item in it before the format can be set. Hopefully this will be eliminated in the future, so that we can set the format of a completely empty folder.
The key is to use the Add Shortcut>>> button in the Organizer which effectively clones the folder into the Publisher set. That should eliminate any missing documents.
Link.
Thanks all. Makeing a folder in the publisher set works like it is supposed to. Just another step that seems unecessary.
Djordje
Seems is the key word 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Archicad 9 was a pain in the ass to print correctly (saving into .plt) and until I finally got the hang of it. Then I upgraded to v10 only, to my horror, find out they ve changed the procedure. I haven't needed to use the Plot command yet, thank God, but I will be soon. And I hope it makes sense this time or you might read some censoring from me too to steam off.
Djordje
Frankly, saving to PLT is not a good idea at all - because the PLT format is a historical thing, a remnant from the actual pen plotter era, now good 10 years behind us.
Maybe you should rethink the procedure and use something more up to date?
And why plotting when you have printing?
Nothing has changed in the actual procedure, "except" the layout integration, therefore no separate PlotMaker. You can still have a separate file with the layouts only.
Djordje
HP Omen
It was just that I was in a really, really bad mood that day...
Thankfully gunpossession is illegal...
Yes I had to get into plotting yesterday and I was pleased to see that the basics havent changed and I can get up to speed pretty quickly.
The reason I'm using .plt is because I send my drawings to a photocopy shop. If you know of a better way perhaps you can let me know. It's fine once you know what you need to be doing with a little experimenting.
The bad thing is that I can't even get a preview print from my A4 laser (Kyosera FS-1010). Even selecting the printer from inside AC10 (or v9 for the matter) crashes ArchiCad instantly and sends me to the desktop. Can't be bothered to look into it.
But if you can think of a better way let me know.
Djordje
The obvious answer is PDF. However, that depends on whether your local shop wants to do it or not.
The Bug Report starts and you fill it up and send it, right? Plus, you email your tech support with the ID of the Bug Report?
Or you can't be bothered? 😉
Check the printer drivers, and set another printer as default - let's say the Amyuni PDF. It could also be that the printer does not have enough memory.
Djordje
HP Omen
