Eric Milberger
Help with Zone Label - How do I stack text
How do I CENTER stack text as in the name PUBLIC LOCKER ROOM
PUBLIC
LOCKER
ROOM
Eric Milberger, Architect | Master Planner
6 Replies 6
Lingwisyer
Guru
You have to turn on Text Wrapping, then set the max width of the text box... The width is scale sensitive... You can disable this scaling if you edit the start of the objects 2D script.
Ling.
Eric Milberger
There is NO Wrap Text in the Zone selection
Eric Milberger
ND IT ALSO DIES NOT LET ME DROP THE BORDERS AROUND THE LABELS AND
I CANNNOT EASILY SELECT THE BOXES TO EDIT
Lingwisyer
Guru
What settings do you have under Text Style?
It looks to me like you are using a zone stamp and Ling has shown you a zone label.
There may not be a 'width' value in a zone stamp but there may be a 'number of characters per line' value in the parameters.
But that may depend on the stamp you are using, they all have different settings.
Lingwisyer
Guru
That would explain the missing text settings.
You can force the width of the stamp in the same way. By default the option is unchecked and the width matches that of your zone name.
Ling.
