2023-07-20
04:12 AM
2024-08-31
03:07 PM
We are using macOS and ArchiCAD 24, and we have also encountered this issue in previous versions.
We use the Helvetica font that comes preinstalled on macOS. When we publish to PDF, all text using this font disappears.
Other users on the same teamwork file do not have this issue, and it does not affect other PLN files. This happens randomly, and it is not isolated to a specific macOS version
We would appreciate any help you can provide in resolving this issue.
2023-07-20 05:30 AM
Single file on a single computer? Single file on multiple computers?
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2023-07-20 06:16 AM
Strangely enough, this has happened to different files on different computers
There have been a couple of not very good workarounds - restarting the computers sometimes helps, in other instances, we had to reinstall the font
2023-07-20 02:21 PM
This occasionally happens to us. Different fonts. Re-starting the publishing computer and re-publsihing has, so far, solved the problem.
2024-08-29 03:11 PM
Hi everyone,
This issue came to our attention when one of the users reported it to technical support, so although it's probably not relevant anymore, I'd still like to share some notes here if anyone else runs into it in the future.
Since restarting the computer resolves the issue, it seems that there might be something wrong with the font cache.
By default, the Helvetica font comes in TTC format on macOS. We can use only TTF fonts directly in PDF export, other font formats are converted to TTF before being used in PDF and then stored in cache.
Based on this I can offer several recommendations:
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer
