2005-05-19
10:04 PM
- last edited on
2023-05-26
02:37 AM
by
Gordana Radonic
2005-05-20 07:22 AM
MikeS wrote:Set the Dispaly option in the ArchiCAD view appropriately; you will have to save separate views (probably at different scales) with separate Display options
First issue (of 2): Is there a way to suppress the door and window markers in either the .pmk or the Layout?
MikeS wrote:You can, if Printing, not Publishing, by setting the numbers of copies of selected layouts in the Print dialog box.
Second issue: Is there a 'global' way to publish (print) multiple copies of layouts without setting numbers of copies in the individual layout's setting in the Publisher's options?
2005-05-20 10:50 AM
