Hiding Window ID markers in Plotmaker
First issue (of 2): A colleague is working on a complex multi-storey building. In accord with our office protocol, he is creating .pmk files for inclusion in his layout book, but is finding that the number of .pmk files he needs is becoming unwieldy, and because we always include the linked .pmk files in the layout book, his layout book is getting very large.
I suggested that he rationalise this by reducing the number of .pmk files by saving all used attributes and layers with the .pmk file and thereafter control the layers' visibility in the layout book.
One snag: he saves the file with all window and door markers visible, but in some of his layouts in the layout book the window/door markers detract considerably from the clarity of the information.
Is there a way to suppress the door and window markers in either the .pmk or the Layout?
My suggested workaround is that he saves two .pmks for each storey, one with window markers visible, the other without them being visible.
Second issue: Is there a 'global' way to publish (print) multiple copies of layouts without setting numbers of copies in the individual layout's setting in the Publisher's options?
Thus we would set the default for each layout individually to one copy, but on the occasions when we need multiple copies we would like to be able to publish, say, six copies without having to reset the number in each individual layout's options each time we come to publish/print.
At present we publish once, repeat the process, and continue until the required number of copies has been printed. This is so time consuming, and particularly so when only selected layouts are to be printed n times!
Djordje
MikeS wrote:
First issue (of 2): Is there a way to suppress the door and window markers in either the .pmk or the Layout?
Set the Dispaly option in the ArchiCAD view appropriately; you will have to save separate views (probably at different scales) with separate Display options
Why still PMK?
You can, if Printing, not Publishing, by setting the numbers of copies of selected layouts in the Print dialog box.
If you are Publishing subsets, you can set the number of copies by subset; this has to be set each time.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje
Why still PMK, you ask. Our staff is new to ArchiCAD, and we need the 'security' of the additional process whereby the user has to think before saving the PMK, and then, finally has to think again before updating the layout book.
Mike
