How do you open a .lay file?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2024-02-08 10:09 AM - last edited on ‎2024-02-08 10:18 AM by Barry Kelly
Good day
I am trying open some files that were backed up from a very old project which were saved in .lay format. I am using archicad 15 on an i macOS X El Capitan Version 10.11.6.
I tried installing Archicad 8.1 onto the iMac which I believe has plotmaker which may be capable of opening the .lay files, however, my I Mac sends up the message "power pc application no longer supported". I realised that even if I am able to install archicad 8, I don't have the old license keys.
Is there any way that one can now open .lay files without having to use plotmaker or one of the older applications? Is there a file converter perhaps?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-02-08 11:49 AM
They are here:
https://graphisoft.com/downloads/fileconverter
Also try using File->Interoperability->Merge to check if it imports the file.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-02-09 08:56 AM
Hi Eduardo
Thanks for such a fast response. Unfortunately, the download links on the File Converter page don't work. I've tried using the Merge function, but it also didn't work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-02-09 07:41 PM
Notifying the issue for the downloads.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-02-09 09:13 PM
The file converter versions of Archicad won’t work on modern Mac operating systems. I have to keep a copy of Parallels Desktop to run Windows which has the older file converter versions of Archicad to be able to open our old projects from Archicad 5 to 10.
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
