How do you open a .lay file?
Ameen
Good day
I am trying open some files that were backed up from a very old project which were saved in .lay format. I am using archicad 15 on an i macOS X El Capitan Version 10.11.6.
I tried installing Archicad 8.1 onto the iMac which I believe has plotmaker which may be capable of opening the .lay files, however, my I Mac sends up the message "power pc application no longer supported". I realised that even if I am able to install archicad 8, I don't have the old license keys.
Is there any way that one can now open .lay files without having to use plotmaker or one of the older applications? Is there a file converter perhaps?
4 REPLIES 4
Eduardo Rolon
They are here:
https://graphisoft.com/downloads/fileconverter
Also try using File->Interoperability->Merge to check if it imports the file.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Hi Eduardo
Thanks for such a fast response. Unfortunately, the download links on the File Converter page don't work. I've tried using the Merge function, but it also didn't work.
Eduardo Rolon
Notifying the issue for the downloads.
AC27 US/INT -> AC08
another Moderator
The file converter versions of Archicad won’t work on modern Mac operating systems. I have to keep a copy of Parallels Desktop to run Windows which has the older file converter versions of Archicad to be able to open our old projects from Archicad 5 to 10.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
