ID Hatch
marcocioeta
Hello to everyone.
A very basic question.
I have an ID of the hatch (see the attached image) with a three-part text.
Can anyone tell me how to split the ID of the hatch with a customized label?
thank you
Operating system used: Windows 10 pro
5 REPLIES 5
Matteods
Hi what do you mean with splitting? Maybe can be useful to create a Pset with different fields for this task?
If I have the hatch with in ID, and for some reasons I want only the third part of the text, can I split with a label without erase some part of the text?
Matteods
Hi I'm sorry i think not! And if it's just an hatch I think you can not even use a pset for it. Maybe is better to use zone stamp that is an object and you can have a lot of option for it. What are these surfaces for? It seems like a cadaster. If you use select the zone stamp and you use the magic tool you can transform hatches into zone.
Check Expression-defined Properties in the Archicad Online Help.
You can create an Expression-defined Property, and you can use the expression to take the part of the ID after the second underscore character, there are functions to achieve that.
Then you can just use that Property in your Fill Label.
Nice to know thanks 😃
Setup info provided by author
