on
2022-07-14
03:00 PM
- edited on
2022-09-28
01:20 PM
by
Oleksandra Vakariuk
The Level Dimensions update in Archicad 26 focuses on avoiding repetitive tasks to save time on creating documentation. These new functions requested by our users make using this tool faster and more efficient.
Before Archicad 26, it was possible to edit the text and add further information in the Dimension Text Settings only after placing the dimension and only one-by-one. These constraints have been resolved in Archicad 26.
Let’s take a look!
Set the dimension origin by default before placement and store the settings in favorites:
Associate the value displayed in the dimension text to various levels of the structure concisely in the Level Dimension Settings dialog Text Content tab > Multi-line option using the Insert Autotext bar.
The Insert Autotext bar will open a list of available level references logically organized into groups.
When customizing the text content, you can type any text you need, add new lines, line gaps, etc.
When associating dimensions to slabs and roofs: there are new options to associate to Top, Core Top, Core Bottom, or Bottom of the element.
In addition, there is a search bar at the top of the list to make it easy to navigate and search for any option you need.
The text alignment options (left/center/right) are now directly available in the Level Dimension Tool settings under the Text Style tab (previously, they were only available in the Dimension Text settings).
Note: each Partial Display mode has its own set of dimensions. If you switch between Partial Structure Display settings, the dimensions associated with the earlier display setting will not be visible.
With this improvement to the Level Dimension Tool, you can customize the text directly in the Level Dimension Tool settings dialog before placement, avoiding the need to adjust it one-by-one after placing it on the plan.
You can even save your custom text content in the Level Dimension settings as Favorites:
In Archicad 26, the Level Dimension Tool enhancements concentrate on helping our customers stay focused and design more. Now, there is less need for workarounds or manual texts and adjustments by using the information already in the model in new ways.
Create documentation faster by using the information already in the model in new ways with the improved Level Dimension Tool.
Learn about all the new documentation features of Archicad 26:
To learn more about all the new features of Archicad 26, read this article.
