RJSNZ
Is it possible to use the name of the clone folder in a drawing title
When documenting a multistory building I will use several "clone folders" in the view map for generating the various plans needed.
When setting up a layout on a sheet, within the "Drawing Title" is there a tag similar to <DRAWINGNAME> which i could use to reference the view map title of the Clone Folder?
Ie <DRAWINGFOLDER> : <DRAWINGNAME> to auto title "Fire Plans : Ground Floor"
Operating system used: Windows 10
1 Reply 1
max_min
AFAIK there is no built-in AutoText tag that directly references the name of a View Map folder or Clone Folder to be referenced within your drawing title.
The available AutoText options related to a drawing (such as <DRAWINGID>, <DRAWINGNAME>, <RENOVATIONFILTER>,etc.) pull from the metadata of the specific drawing itself, but they do not capture information about the folder in which the view is located (such as a Clone Folder or View Map folder name).
I can see how this would be helpful, would recommend submitting it as a wishlist item
For reference, here’s a list of all currently available AutoText tags:
https://help.graphisoft.com/AC/28/INT/_AC28_Help/070_Documentation/070_Documentation-69.htm?rhhlterm...
MacOs Tahoe | Archicad 13 to 29
