Pato99
Is there a way to publish in text format
Is there a way to publish in text format such as txt, XML or CSV format for generic content (Not schedules).
I'm trying to export... no Publish the project info or auto text into a txt file or XML that can be added to a database or even just searched in for key words with a windows utility.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
4 Replies 4
Erwin Edel
Project Info can be exported to xml.
File > Info > Project Info > export
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Pato99
Yeah, sorry that's not what I was asking. I want to publish the project info, not export it and I'd prefer it to be formatted nice with autotext but not be a pdf.
Erwin Edel
I suppose, in theory, you could script an object to call all the autotext fields, schedule that object and publish it text, but there's no back and forward in that.
Are you using custom entries in project info for something clever? Maybe this can be achieved with the new properties system in ArchiCAD20 instead. This allows interoperablilty through schedules and excel, for example.
www.leloup.nl
Pato99
Yes, I'm using custom fields for a multitude of things, master layouts and marketing layouts are the most common, but I also database the XML exports for fun. If this was reliable I'd be able to build a more sophisticated database.
Using the properties system is an interesting idea, but I don't think I'll be able to use it in any auto text situations. It's a "catch 22" but I do like it and I'll look into this further!
