Lingwisyer
Guru
Label Alignment
Hi all,
Is there a way to get the align function to move the label Handle Node rather than the Leading Line Node?
I do not remember seeing any updates about this, but maybe I missed it. Was just telling someone to align everything left and that all of the leading nodes would need to be adjusted manually afterwards... It is not like the tool does not define the Pointer Starting Angle...
Ling.
Operating system used: Windows W11 25H2
1 Reply 1
Patrick M
it depends on how you select the label. If you select by the leader, you are editing/aligning the entire label. If you select by the text box, you are editing/aligning just the text box.
aligning text is pretty simple. aligning just the leader/pointers is a tedious, one at a time, procedure
