Yvonne
Label length of gridline
Is there a label that can pick up the length of a gridline?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
2 Replies 2
Ricardo Lopez
I am not sure if a label can be directly used for that, but you can create a Schedule using the library part parameters from the gsm grid object, as seen on attatched image.
(Maybe editing the GDL object could be another way to solve it...)
Ricardo López, M. Arch.
Eduardo Rolon
If I understand correctly, discussed previously here.
https://community.graphisoft.com/t5/Wishes-forum/Grid-Elements/m-p/254336
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
