Lable
Hi!
Question, in Archicad, 19 when you drag a copy of a simple label text why the arrow leader remain attached at the original one ? Any suggestion how avoid that?
Thanks
3 Replies 3
Hi, That happens when the label is associate to an element. In this case use the pick up parameters (eyedrop) (crtl) and make a new one, it will keep the text you wrote. As an extra, if you make a label that is not associate with any element, then you will be able to drag a copy with no problem.
Thanks
James B
In AC19, if you only select the text box then that is a sub-selection (ie only the text box is selected). If you click the leader then the entire label will be selected.
Labels now behave more like dimensions - ie the text is a sub-element.
James Badcock
