Benluwizzy
Maker text style and Maker custom settings is grayed in window settings in my ArchiCAD 28. How to re
5 Replies 5
David Maudlin
Benluwizzy:
Which Marker is selected under Dimension Marker?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
To expand on what David wrote:
Make sure that you have selected an option other than the "No Marker" option for the Dimension Marker.
Benluwizzy
Thanks I appreciate, I'll do that 🙏
Benluwizzy
Actually the option selected under "Dimension maker" is the "No maker" option
That is why those two panels are disabled. They are enabled only if you select a Dimension Market for which there is an interface defined in its GDL script. So, you need to choose another Dimension Marker.
