Material not being overridden in plan
Howdy,
I think I have an issue with my renovation filters. I have marked some walls in red circles in attached image. You can see these walls are showing material markings unlike all the other walls which are filled with solid black. The walls that are showing differently are all "new construction" whereas all else is "existing", which leads me to believe it'll be something in the renovation filter.
I don't think I understand the difference between "cover fills" and "cut fills" to be able to identify where I should be looking.
Any help appreciated.
David Maudlin
TightKnit:
Check the Renovation Filter you are using and see if New Elements is set to Override. If so, check the New Elements Graphic Override Rules, it could be overriding the Fill Type.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
David Maudlin
TightKnit:
SOLVED
Thanks David! Indeed, it is all in the overrides. The reason all the other walls in "Existing" are black is because they are being overridden. I can do the same override to the walls in "New Construction".
David Maudlin
TightKnit:
Good to know that worked, thanks for posting back.
