a week ago - last edited Monday
We are using the Variable Window INT object for most of our windows. In this project we are placing reversible (aka pivot hung windows). (FYI USA standard is opposite of European and probably the rest of the world: 1 point at hinge / rotation center, 2 points at handle. If anyone knows the logic behind the US method, please share...)
Anyways, Model View Options doesn't reverse the lines if I set orientation from handle to hinge or vice versa, it constantly shows the EU standard "diamond", instead of an X.
Issue is with the following opening types:
Reversible Horizontal
Reversible
Reversible Mirrored
Furthermore: the same problem with the USA dedicated object, W Pivot Hung. Same diamond shape instead of an X, no matter what I set the line orientation in the USA MVO settings. (BTW, it would be great to have the same MVO panel for USA and INT windows, I see no reason for the double settings.)
Even further more: Seems to be the same problem with Skylights!
(Archicad 29.2.0)
a week ago
- last edited
Sunday
I know when I was setting up our AC29 template I made some MVO changes, and didn't see any adjustments.
There is an INT tab as wall as a USA tab. I made all my changes in the incorrect tab, rather than the USA specific one.
Saturday - last edited Saturday
The double tabs is very annoying by itself and I beg Graphisoft to merge the two, but that's not the problem here: the diamond shape remains no matter which tab I'm using. (Even more: Skylight is in a third tab.)
Sunday
I am not 100
% sure if this will help as I don't use the default Graphisoft libraries by default and I usually don't load other language libraries.
But it may have something to do with Library Localisation Preferences and mapping tables.
See this post ...
It should link to a post that I made and then read from there to the reply that was accepted as the solution.Hopefully this might help.
Sunday
Ruling out all that from using language version A and loading language libraries B, and also yummy stuff like migrating older projects etc., I opened Archicad INT 29, created a new file based on the Graphisoft INT template. Nothing else loaded, new Archicad project out of the box, as Graphisoft dreamt it. I created window with the basic Window object and the problem is the same. No matter what I set for opening line orientation in MVO, the diamond shape persists. All other opening types (side hung, top hung etc.) work as they are supposed to.
Side hung window, MVO at hinge: >
Side hung window, MVO at handle: <
Reversible window, MVO at hinge: ⬦ [diamond]
Reversible window, MVO at handle: ⬦ [diamond] (should be X)
Monday
OK I just looked at the default windows and I can see what you mean.
Firstly I don't use the default windows and in my part of the world we rarely have tilt & turn or reversible windows.
I don't even understand why there is a 'mirrored' version and you can choose the hinged side as you place the window or simply mirror the window when placed.
But that is not the point here.
To me a reversible window should be a double X - left side hinge and right side hinge overlaid on each other?
Like this ...
And there would be no need for a 'mirrored' option at all as the window can already open from either side.
The diamond swing lines to me are just simply wrong.
To me that is a centrally pivoting window.
But as I said, I am unfamiliar with these configurations as I have never used them.
To me the diamond is not logical.
I do agree with you.
If there is a 'reversible' option, it should appear to be different in some way.
Monday - last edited Monday
Like this ...
I don't think that is a reversible window. They are more like this:
Besides the point, but the terminology is a bit hazy when it gets to Archicad. What Graphisoft offers are center pivot windows (horizontal or vertical). But I think it is OK to use them for reversible as well since their mechanics are complicated and a center-pivot is a simple way to symbolize them.
See the 3D previews:
Reversible
Reversible - Mirrored (note: it does make sense to have mirrored version, because you might have an asymmetrical complex window with sidelights etc. and mirroring the full window is not an option)
Reversible-Horizontal
To summarize: the diamond opening lines are correct for European standards, but not correct for US standards (should be X) and there is no way to correct them in MVO!
Same issue with center pivoting skylights as well.
