Need help with a layout sheet that changed
WMac
I’m having an issue with my layout sheet that have my details in them. See attached. Look at where the titles appear below the detail. Now look at the next item and where the titles are appearing. Please advise on how to correct this, I'm sure I messed up a setting or something.
When I first open the sheet, it looks correct. When they refresh, the all pull up into the drawing.
2 ACCEPTED SOLUTIONS
CosminF
Try setting the view to use the internal origin. Go in the layout, select the placed view, go in its settings and use this checkbox:
Hope it helps.
edit: this should work on re-placed view, It cannot views that already "jumped" to another position.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
WMac
Thanks, that lead me to the issue. I had to reset the "Positioning" under drawing title in the setting.
CosminF
Hope it helps.
WMac
Setup info provided by author
