No doors and windows on a layout (visible on the source drawing)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-05-10
02:24 PM
2023-05-26
12:01 AM
Gordana Radonic
A problem with the doors and windows. They are visible on the source view, but at some point they disapeared from the views that were placed on the layouts. What the? Any ideas what might cause the problem?
Source view with visible a layout underlay - you may even notice, that the doors and windows appear differently on the layout (orange underlay in the openings):
Layout:
Thanks!
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-10 04:21 PM
It's recommended to organise project view map - make folders structure. Then it will be easier to avoid similar errors.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-11 07:32 AM
The one on the left represents wrongly, the one on the right is correct. There are no dfferences in the cutting plane either.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-11 11:30 AM
Did you check the FPCP for each ViewMap?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-11 11:36 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-11 11:59 AM
Braza wrote:Yup - both has the same settings.
Hi Piotr T,
Update - Some of them has different settings, but changing them does not affect the representations of a view on a layout.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-11 12:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-11 02:16 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-11 04:24 PM
Another thing I would try before giving up is to utilize the drawing manager and and change one setting for all drawings forth and back to forcefully regenerate all drawings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-13 01:59 PM
nothing worked so far. We have manually changed the views. The problem persists, so only one member of our team is allowed to update the views - on other computers, as soon as the view is updated, the windows and doors disappears and there is no way to bring them back. So frustrating! Even our local Archicad dealer has no working way of solving this problem. I suppose it may be just a bug - the file is huge and complicated, works in a temawork, so there is a lot of data going in and out. A team of 3-4 people is interacting within it so it also may be a "PEBCAK" but if that would be the case it should be "solvable" but so far - it's not
