OPEN GL in V25
Tom Krowka
Hello all.......Am running V25...just upgraded.   I noticed that in the 3D styles dialogue box (after opening a 3D window) I only have engine choices of vectorial engine and hardware acceleration.     Is open GL not available any more?  Is my graphics card outdated?    Have been running V24 and it still shows up on that version.
Thanks Tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
Archicad runs on both Windows and Mac, so I guess Graphisoft developers had two choices:
1. Keep calling it "OpenGL Engine" on Windows, and "Metal Engine" or something similar on Mac.
2. Come up with a naming that can be used on both platforms.
So they chose option 2., and renamed it to "Hardware Acceleration".
If you see textures in 3D, you are using OpenGL on Windows since the Vectorial Engine can not display textures.
CineRender was never available in the 3D Viewpoint.
In the Surfaces Dialog, you should have 3 options in Ac25 in the "Engine Settings" field:
  • Basic Engine
  • Cineware by MAXON
  • Hardware acceleration.
Is Cineware available in the "Engine" field of the PhotoRendering Settigns Palette?
16 REPLIES 16
runxel
Hero
It has been renamed, since on Mac there is no OpenGL any longer (which has been replaced by Metal). Thus a more general term has been used.
Tom Krowka
Am running Windows 10, not MAC.  What is Open GL renamed to?  And how can I determine if it's running in any of the 3D views.  Am also missing Cinerender engine both in the 3D views and surface textures dialogue box.
Thanks Tom
Thomas@wkarchwk.com
www.walshkrowka.com
  • Basic Engine
  • Cineware by MAXON
Cineware does show up in Photorender settings.   Thanks for the info.   I thought I had missed something when loading up V25.  Tom
Thomas@wkarchwk.com
www.walshkrowka.com
Thanks for the explanation and makes sense to align the reference. I’m wondering if there’s also been a change in setting as my models appear jaggy on screen in v25 compared to v24. To test this I created a simple 3D view of the same shape starting a new file from the same templates (only the relevant versions) and noticed that v25 3D views still look much more jaggy edges compared to v24. I just updated 25 to build 4013 to check and it’s still the same. All view settings and overides are exactly the same.
Am I missing something new in v25 to adjust? I've added a side by side screenshot of the simple walls comparing the edges in 3D.
AMD Ryzen 5 5600X 6-Core 4.60 GHz | 32 GB RAM |M.2 500GB + M.2 1TB | 2x Dell 27” | WIN 10 Home 64
NVidia GeForce RTX 3060 12GB (Studio Driver)
Archicad 27 (Since v12)
In AC25, is the "3D Antialiasing" checkbox checked in the "Advanced Redraw Options" page of the Work Environment Dialog?
I checked that and it is checked. Set to the same as AC24
Hello! I have the same problem here. The only difference that I saw between AC24 and AC25 is that in AC25 there's no more OPENGL in the 3D Engine checkbox.
OpenGL is now called "Hardware Acceleration".
It does not look so bad on my screen (I do not have a high res monitor).
There is slight pixelation, but it is not annoying.
However if I go into the Work Environment and turn "3D Antialiasing"  on or off, I can't tell the difference.
But I don't see any difference in 24 either.
