PDF problem with Archicad 18 and yosemite
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-02-05
09:40 AM
‎2023-05-19
10:12 PM
Gordana Radonic
‎2015-02-05
09:40 AM
When creating a PDF of a project with a composite structure containing insulation it generates a very heavy and very slow PDF file taking several minutes to display.
If I change the composite structure to a simple wall the problem disappears and the pdf file size is dramatically reduced.
This problem occurs with only a few walls and nothing else on the plan.
Is there a way to reduce the file size of the PDF export?
I use Archicad 18 on an iMac with yosemite.
Thanks for the help.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-06 12:09 PM
‎2015-02-06
12:09 PM
Sounds like your insulation fill pattern either needs simplified or you have a very dense pattern. The denser the pattern the longer it will take to display.
Have you possibly got duplicated patterns overlaid, that would also add to a slow display.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-12 02:29 PM
‎2015-03-12
02:29 PM
I just found a nice little Blog post by CADImage on reducing published PDF file sizes:
http://blog.cadimage.com/2015/03/reducing-the-size-of-your-windows-pdf-files/
Actually, the blog post says it is for Windows. So my question is: don't you guys on Mac have the same settings you could use?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-12 04:42 PM
‎2015-03-12
04:42 PM
Yes, we have the same dialogue box on the MAC Lazlo.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-12 04:55 PM
‎2015-03-12
04:55 PM
OK, good, so these tips can be followed on both platforms.
