julienK
PDF problem with Archicad 18 and yosemite
When creating a PDF of a project with a composite structure containing insulation it generates a very heavy and very slow PDF file taking several minutes to display.
If I change the composite structure to a simple wall the problem disappears and the pdf file size is dramatically reduced.
This problem occurs with only a few walls and nothing else on the plan.
Is there a way to reduce the file size of the PDF export?
I use Archicad 18 on an iMac with yosemite.
Thanks for the help.
4 Replies 4
DGSketcher
Legend
Sounds like your insulation fill pattern either needs simplified or you have a very dense pattern. The denser the pattern the longer it will take to display.
Have you possibly got duplicated patterns overlaid, that would also add to a slow display.
I just found a nice little Blog post by CADImage on reducing published PDF file sizes:
http://blog.cadimage.com/2015/03/reducing-the-size-of-your-windows-pdf-files/
Actually, the blog post says it is for Windows. So my question is: don't you guys on Mac have the same settings you could use?
DGSketcher
Legend
Yes, we have the same dialogue box on the MAC Lazlo.
OK, good, so these tips can be followed on both platforms.
