‎2016-07-08
07:40 AM
‎2023-05-19
10:11 PM
Gordana Radonic
‎2016-07-08 08:56 AM
‎2016-07-08 09:00 AM
Richard wrote:
Edit>Reshape>Resize works pretty well using the graphically resized option. Or you can select and go into the drawing settings, and do it mathematically under the magnification percentage. (e.g. 13'-2" / 12'-8" = 1.039474, so set the magnification to 103.95%)
‎2016-07-08 09:37 AM
‎2016-07-13 04:41 AM
Richard wrote:
Okay. Select the PDF. Select Resize, and make sure that "Define graphically" is checked. Now pick two points on the PDF that you know the stated distance between. (e.g. 13'2") Now you will get a rubber-bandy line that starts at the first point you picked. Use the tracker to type 13'-2". It will resize accordingly. As Duane Valencia used to say [sic], "viola!"
