‎2004-05-06
05:14 PM
‎2023-05-26
02:38 AM
Gordana Radonic
‎2004-05-07 12:32 AM
‎2004-05-07 10:33 AM
‎2004-05-07 02:42 PM
‎2004-05-07 08:04 PM
Pete wrote:You only have to define your Masters with the device margins, and always use device margins when printing. In any other case, you have to scale down. Be sure to define the master for the device you are printing it on.
Then when I'm printing, under print options the Layout Size shows 2 pages. To fit the drawing onto one, you have assign one of the shrink options. This can be dangerous when people start scaling off the prints on site!
‎2004-05-12 03:55 PM
‎2004-05-13 11:48 AM
‎2004-05-13 02:32 PM
Here is the problem more defined. I have three master pages. Each one is defined for a different piece of paper. 8x11, 11x17 and 24x36. Now when I want to print out the 8x11 sheets I need to change the Page Setup to 8x11. No problem here. The problem is when I open the layout book to print one of the 24x36 sheets and the file had been left to print on 8x11 I do not see any page breaks on the 24x36 layout to tell me the current page setup is set for 8x11.Each master sheet has its own printer/plotter settings. In order to see the page breaks for 8x11 pages on your 24x36 sheet you need to open the Master for the 24x36 sheet and set its page size to 8x11, uncheck "Set Layout Size to Usable Print Area" and set the number of pages you need for the layout at the bottom of this dialog box. Hope this is what you are looking for.
This is what I am looking for.
Is anyone else using the Layout Book for different page sizes?
‎2004-05-14 10:42 AM
‎2004-05-14 01:04 PM
laszlonagy wrote:I don't think you are correct about each Master having its own print/plot settings (it could be a nice idea though). I just plotted a layout book with different sized sheets and had to redo the plot settings for each sheet size. I believe this is also true for printing.
I got it.
I think that each Master Layout has its own setting for the printer/plotter. So when you use that, it will override what is set in Page Setup with what is set in the Master Layout settings Dialog. This is why there are no page break lines because it is not that page size.
Is this possible?
Laszlo
