Placing External Drawing
GSButler
I am trying to place external content - a tif file - into an independant worksheet. It doesn't indicate any error, but the file is not visible. Any clues??
Maitland and Butler Pty Ltd
AC18 - Windows 7 64-bit
4 REPLIES 4
Maybe there is something wrong with the resolution of the TIF (like its 32-bit with alpha channel).
Try to convert the file to some other image format and see it that will be visible.
GSButler
Hi Laszlo
thanks for your reply - other formats work OK.
The tif file which doesn't work is 24bit, 4960x3507pixels, 546Kb at 300dpi resolution.
Is there a maximum size Archicad 13 can handle?? I scanned the plan here at the office, so if there is a limit it would be good to know.
The maximum image size AC can handle is 32767 x 32767 pixels.
I think the reason it could not handle the TIF is because TIF can be saved with various compression methods. There are several of them. Probably the file was saved with a compression method AC does not recognize.
GSButler
I should know by now that Archicad can do ALMOST anything! 37000x37000 pixels is pretty good!
I'll experiment with the compression methods - thanks for your reply. Cheers.
