2005-06-08
09:07 PM
2023-05-26
12:15 AM
Gordana Radonic
2005-06-10 08:38 PM
2005-06-12 11:56 AM
chriszolezzi wrote:Do your subs know about PaperSpace?
When i publish the layout book to DWG all the drawing titles disappear I am not sure if it is a problem with plotmaker or in the DWG translator. The information on the titles are important to my subs and I have been unsucessfull at finding what the problem is or why it is happening.
2005-07-09 03:50 PM
2005-07-11 02:56 PM
2005-07-11 03:45 PM
"Keith JAW" wrote:
Jaime -
"Are you aware that the default translator saves your layout an Autocad paper space drawing with nothing at all in model space".
— No Keith, I was not aware of that fact.
"When you open your .DWG file in Archicad, Archicad wants to open the model - and finds nothing there, although if you open it in Autocad you will see your layout in paper space".
— So I guess there is no way to check a published .DWG file from PlotMaker within Archicad 9.0...
"You can set up your own translator, and select the option "Paper Space with Full Drawings' content". "
—Thank you Keith for sharing your knowlwdge and insightful tip!
Jaime Neto
2005-07-11 04:00 PM
