‎2005-01-14
07:52 PM
‎2023-05-26
12:15 AM
Gordana Radonic
‎2005-01-15 09:02 PM
‎2005-01-16 11:05 PM
‎2005-01-17 11:28 AM
‎2005-01-17 11:45 AM
‎2005-01-17 01:33 PM
patricprz wrote:
You mentioned the text being a problem. After installing AC9 started using text in mm by default. So are you saying that i should be using the text tool always with points?
patricprz wrote:
At least the problem is creative. When I started out the DWF would arrange everything in a line in the centre of the page. Now that I have moved everthing to the 0,0 origin everything is arranged in the lower left corner in a circle. (see pic)
patricprz wrote:
By the way, how do i select Text in the entire drawing not just on one floor?
‎2005-01-17 01:35 PM
‎2005-01-17 01:39 PM
patricprz wrote:UNBELIEVABLE !!!!!
Ok, check this out. I have been trying EVERYTHING and I discovered something.
If i draw a slab around (thin red line in the pic) the DWF published correctly.
I still don't know what is causing the problem.
‎2005-01-17 01:46 PM
‎2005-01-17 03:24 PM
‎2005-01-17 07:06 PM
patricprz wrote:Units don't matter. What does matter is whether the text is scale sensitive or not. If you use fixed text, you are working like in AutoCAD - specifying the text size in project units, instead of the printed size which was ArchiCAD's default until 9. IMHO it should have stayed so.
