‎2020-06-25
12:29 AM
‎2023-05-19
10:07 PM
Gordana Radonic
Solved! Go to Solution.
‎2020-06-25 10:29 AM
‎2020-06-29 04:02 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-06-30 06:48 PM
‎2020-07-01 08:01 AM
Jp1138 wrote:Hi,
The "Allow to explode or copy contents" avoids someone writing or taking things from the pdf. I don´t know Plangrid, but from the looks of it it´s similar to Bluebeam Revu, and the app needs to write to the pdf to make marks, etc. You must leave your pdf "completely open" as far as I know to be able to do it.
The password protection option asks for the password to even open the document, so they cannot even see it without the code. It´s a different option.
I think this is the way this works, but I maybe wrong as I don´t usually use any protection options as it only difficults the use of the files, and they can copied, modified, etc anyway if the other user really wants to.
Minh Nguyen
GRAPHISOFT
‎2020-07-01 08:18 AM
joelsdg wrote:Hi Joel,
Jp1138, thank you. I have come to realize that you are correct, sadly. In order for our PDFs to work with Bluebeam and Plangrid (in a manner our contractors use those apps), we have to release fully editable PDFs.
Minh,
I am a bit confused by your answer. How can an option for security create a password that is unknowable? Why is this a 'feature'? It seems to be a bug, in my opinion.
Our firm may be late to the party on this type of project distribution, but we have used it exactly twice and gotten this same result two times because our contractors use the same software. Since this is the case, I assume both Plangrid and Bluebeam are fairly ubiquitous in the industry (at least in the USA). But you seem to be telling me that these industry-standard apps can't play well with ArchiCAD's PDF generator. Why is this? It appears that our only option is to release a fully-editable PDF, or one that our consultants can't properly use.
Am I missing something here?
I look forward to discussing this further,
Joel
Minh Nguyen
GRAPHISOFT
‎2020-07-01 01:43 PM
mnguyen wrote:
Thank you for sharing your experience with Bluebeam!
Strangely, I cannot reproduce this with Bluebeam Revu 2019.1.20, trial version. Even if I uncheck all "Allow..." boxes, Bluebeam still opens the file as other PDF reader. No password is asked upon opening. The only thing that is different is the annotation/modification tools are unusable in Bluebeam.
Unless I specify a password to open the PDF, then Bluebeam will ask for the password upon opening the file.
I don't know if this is the same issue as you mentioned. Let me know how it goes!
Thank you very much!
Best regards,
Minh
‎2021-11-10 08:11 AM
and of course, there really isn't any way to protect a .pdf anyway with so many online apps that can theoretically "unlock any .pdf" .
