Publishing DWG's
I have been trying to use publisher to create DWG's of my layout pages. When I open the saved DWG layouts to check them, the layout page appears but the drawing on the page is not present.
This has only began happening recently, I am using ArchiCAD 12, is there a setting I need to enable for this to work again?
3 Replies 3
What are your settings in the Translation Setup Dialog?
Specifically the two fields marked at the attached image?
My settings are the same as those in the image you posted. Do I need to change these to be able to view the DWG?
I think the settings are fine this way.
I have one more idea: try to update the Drawing on the Layout and then Publish. See if that helps.
