Sefa Yakut
Publishing layout failed because Archicad was not able to generate it
I get this error when I try to publish a list as .txt in Archicad. When I check the file directory, I see that it is published as .txt, but I get a message that it failed.
I have tried saving to a different file directory and I am sure there are no other .txt files in the background.
Operating system used: Windows Build 5003
2 Replies 2
I just tried and it worked for me.
Double click on the failed item and see if that gives you any more clues.
Maybe try publishing to to the root C-drive - so there are no dashes in the file path.
scottjm
Mentor
Check to make sure you don’t have any fields in the schedule that are referencing properties that no longer exists.
I’ve had the same thing happen.
