2011-07-30 01:28 AM - last edited on 2023-05-22 11:59 PM by Gordana Radonic
2011-09-07 07:20 PM
Dennis wrote:Here's the problem I'm having, my dimensions are on the "New" Status and they show up fine in the view, but once I place the view on a layout the dimension lines show up dashed and gray, which is my override setting for "Existing" status.
Leader lines and dimension lines take on the linetype override settings set in the renovation overrides, so if you have all the demolition items to show up with a hidden line for example, your dimensions and leader notes will show up with hidden lines as well. This can be solved to a certain extent by having the "demolition" notes and dims to actually be "existing" status (thus not taking on the hidden line override of the demolition filter), but checked to show on the "current filter only" with the demolition plan.
2011-09-07 08:10 PM
2011-09-07 08:37 PM
2011-09-25 10:00 PM
2011-09-25 10:48 PM
Catalin wrote:If I understand correctly you can use the same, uniquely named section to create differently named views with different layer and renovation status settings.
Dear all,
I have a problem and maybe you found a workaround.
I have a section A, and with the new AC15 renovation feature I try to have two different section layouts (Existing and Proposal)
In the section marker - 2nd row I try to find out how to have both layouts linked, of course not in the same time.
It's possible to have two different section with the same ID and different name in different layers linked to different layouts, but I need to take care of both section settings instead of one.
Please let me know your thoughts.
Regards.
2011-09-25 11:44 PM
2011-09-25 11:53 PM
2011-09-26 12:03 AM
2011-09-26 02:35 AM
2011-10-03 08:51 PM
