2026-01-23 06:04 PM
When you open Window Selection settings, under Renovation, the Renovation status is not highlighted and you can't change. This affects the window schedule and you can't change it from new to existing or get it to show up on the window schedule. How can I fix this?
2026-01-23 06:56 PM
The wall renovation status is not new?
2026-01-23 07:12 PM
On mine, you can't change it. It's not highlighted
2026-01-23 09:29 PM
if the wall is on the NEW reno status, the window will always have that option grayed out.
archicad won't let you put an existing or demo'd door or window in a new wall.
That is my guess, as to the issue
2026-01-23 10:02 PM
All the walls are new. It's just that the window renovation status is greyed out
2026-01-27 02:36 AM
In a 'new' wall, you can only have a 'new' window.
If the wall is 'existing' then you should be able to change the window reno status.
