Section marker lines disappeared from Layouts
alexliz
No idea what I may or may not have pressed, but they stopped showing in Layouts. All I did was play with the On-Screen View Options in Plan View, I enabled for a moment the Highlight Source Markers option to see what it looked like. Then I noticed the marker lines disappeared from layouts (they showed till then), I went back to revert the on-screen view option, but they are still invisible in layouts.
Anyone had this before and can point me to a quick fix, to make my deadline, please?
I have opened other .pln files and all works fine in them, so I am guessing something got broken with the settings in this specific file I'm working on. But what?
Many thanks!
Archicad 27 macOS Sonoma
alexliz
UPDATE - SOLVED
They weren't Sections. In my haste I had used the Elevation tool, whose marker line is never visible in Layouts. I'm posting this here, in case it helps someone else who in a moment of madness also gets confused and looks everywhere for the solution to a problem that isn't there...
1 REPLY 1
alexliz
UPDATE - SOLVED
