Guillermo1
Section view filters
Hi, why can´t I edit the filter with the alert symbol? it is a section view in the view map.
1 Solution
Lingwisyer
Guru
Maybe because the View is set to "Manual Model Rebuild"?
Go to post
3 Replies 3
Are you sure it is not a worksheet or detail view that you are looking at?
They have those options unavailable (greyed out), but in section views they should be available.
Lingwisyer
Guru
That does indeed affect it.
@Guillermo1 , if you are happy with Lingwisyer's post, please accept it as a solution (3 dots to the right hand side).
