Showing Zones in Sections?
TomWaltz
Is it possible to see Zone names/numbers in Building Sectiions?
..... of should I just post this to the wishlist? 😉
Thanks!
Tom Waltz
7 REPLIES 7
Yes. Put it in the list. It is a good one.
PS. No it is not presently possible, and there is no clumsy work-around since the zone stamp sub-type has no 3D script.
I don't think so...
Speaking of zones. Does anyone knows how to get zone volume in listings or at least as feedback.
Djordje
You have to edit the calc set to include it. It is in the parameter list.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje,
I'll explore more Setup List Schemes. I need grouped volume values. It is easy in plain text format, but it is harder when you have to change existing graphic listings.
Djordje
TRIBU wrote:
Thanks Djordje,
Forget the graphics, use the text and open it in Excel for further usage.
Djordje
HP Omen
If the set is changed, after saving and reopening PLN all the changes are lost, and I get 2 error messages.
Am I missing something or it's just a bug .
