yesterday - last edited 5 hours ago by Laszlo Nagy
Hi everyone,
I'm working on a project where I need to simplify the representation of composite walls, slabs, and complex profiles for scales such as 1:200 or larger. Specifically, I'm looking to merge or display materials marked as "finish" or "other" as a single material in these views.
I understand that Model View Options (MVO) can be used for simplifying certain elements, but I'm curious about the best practices or workarounds that you all might have come across for achieving this effect with walls, slabs, and complex profiles.
See images:
yesterday
I think You should use overwrite options, with a rule that other and finish use the same Settings without a lines between those layers.
yesterday
Hi, thanks for the reply.
As I understand the overwrite options only work per element not per material. I can only overwrite the whole element (slab, wall, ...) Also, there is no rule option for "core", "other" or "finish".
yesterday
Yes, but You can filter by element (wall/slab) and bulding material.
