2023-06-15 04:38 PM
So GS just confirmed in their event that they are not interested in developing the Graphic over ride function to control element visibility because they think that it is to hard for AC users to get our heads around. Seriously!!! We are the ones asking for it. Visibility by layers only is old fashioned and ignores the value that properties & classifications embeds in the element.
2023-06-15 08:30 PM
I personally don't think that controlling it through GO is a good end solution as there should be a distinction between what element is visible/active and how it is graphically represented. But the introduction of truly invisible lines/surfaces/fills would be a quick fix with minimum "confusion" for users.
I didn't see the Q&A but if the answer was to be understood as GS sticking with the current layer-based visibility control for the foreseeable future it sure is depressing. Currently visibility control is all over the place and in urgent need of an effort to consolidate/harmonise/centralise. A criteria based approach would enable just that and at the same time making sure that AC is keeping up with the development, enabling truly object oriented workflows.
2023-06-18 04:33 AM
Agree. It is truly depressing GS still thinks layer based visibility control is still the best way for users.
2023-06-18 10:12 AM
That's truly happened in second Q&A session, I and others asked if we have design options why we still can't hide element in 2D plan??
The answer was from @Marton Kiss proves that GS is interested in hiding elements by layers and said something about a quiz he had before when he was at school I personally couldn't understand well either this quiz or the logic behind hiding layers not elements cuz they were hurry and speaking fast.
Even I'm surprised why Q&A sessions are not uploaded to the events' videos yet despite the same session in collaborate event is exist!!
2023-07-21 04:08 AM
Thanks graphisoft for publishing the Q&A session related to Design Building Together event.
2023-07-24 10:05 AM
Setting up a GO rule to hide a specific element seems just as convoluted as making a new layer + layer combination to me.
Model View Options and Floor Plan Range usually do the trick and you can set most elements to 'ignore' MVO and use a custom setting for the odd ones out.
Can you give a specific case of what you need to hide based on properties?
2023-07-24 01:15 PM
Hiding elements via GO is achievable, but personally I think it the wrong place if you wish for an on/off status. I have already raised a wish for transparency and fade in GOs, but that is from my view aimed at graphical presentation.
@Erwin Edel comments above are valid in the current AC display arrangement, but I do think controlling on/off by criteria / attributes is a better place for development of such a feature and would be a lot easier to manage than using GOs. I did advocate that such a provision could have taken Design Options to a far more advanced level, but as ever we have a solution with limited usability.
2023-07-24 01:42 PM - edited 2023-07-24 01:46 PM
Could/Should adding these criteria to Layers instead of GOs be the option?
Having the existing Layer Palette be the Basic Layer Manager and then having a "Expert" Layer Manager were you could have rule based Master Layers might keep AC simple for new users while giving us extra control.
Layers, control Model vs GOs, control Graphics?
and if this works then Pen Settings might be integrated into GO's to be the Basic UI and GO rules go into Expert Mode…?
another Moderator
2023-07-24 04:28 PM
I know you know all this @Eduardo Rolon , but for those less familiar... As I have tried to explain in various places, Layers are just another attribute of an Element. The key fact is under a BIM workflow, each Element is assigned multiple attributes. The obvious ones which are common to every Element are...
ID
Layer
Renovation Status
Design Option (new)
Structural Function
Position
IFC Properties...
the less obvious material type Core, Finish & Other
and then we have Classifications which when used to control the displayed elements opens a multitude of possibilities e.g. filtering by your preferred classification system e.g. Uniclass, CAWS etc.
All these attribute are permanently active and we use them to determine the presentation of each Element. Yes we can use GO, but supposing I want to just display or export Elements assigned to an attribute e.g. Load bearing, or just the External Elements or an IFC Type, or more interestingly those assigned to a custom classification such as Phase 3! Within the current scope there is no easy way to filter what is presented without potentially developing long lists of layers, which come with an increased risk of layer assignment error as the lists get ever longer. I can appreciate for many, this approach may appear more complex than just Layers, but for the future and definitely for 3D modelling we need to move beyond the current limitations of Layered presentation and start leveraging the potential of 3D & BIM.
Could/ Should this be achieved by a criteria / rules based display system or a simple Layer type on/off system with sub-folders that lets you add attributes & classifications and save them in combinations? - Personally anything would be better than the piecemeal blinkered approach that has landed with a bang with Design Options.
I think from the manual VW has Classification control, it would be interesting to hear how users are leveraging that workflow?
2023-07-24 06:22 PM - edited 2023-07-24 08:09 PM
@DGSketcher We are in agreement, just thinking how to organize the "Saved Views" so that it is easy to teach to new users.
My emphasis is trying to keep it as simple as possible
If we add rules to Layers then GS has to integrate them with Properties/Classifications et al. which is a necessary wish
another Moderator
