Martin Jules
Mentor
Stairs disappear in the Layout Book
Some stairs appear correctly in the View Map but are missing from the Layout Book. What could be causing this issue?
Martin Luther Jules
AC 10-29 (Full)
Asus | 64 GB RAM | Windows 11
1 Solution
Martin Jules
Mentor
It's a bug! Just copy and paste the stairs into a new file, then copy and paste them back into the original file.
Martin Luther Jules
AC 10-29 (Full)
Go to post
9 Replies 9
Martin Jules
Mentor
Martin Luther Jules
AC 10-29 (Full)
In the file where it does not appear on the Layout, is your project located far from the Project Origin? That is one factor that may cause elements to not appear on Layouts.
Martin Jules
Mentor
No.
Martin Luther Jules
AC 10-29 (Full)
This is strange indeed.
Is that text part of the stair object?
If so, why would that show but not the stair.
Or is it separate text you have placed?
Guru
Did you try to repair the file? I feel like I have had this happen before and a repair resolved it.
JeffH
Is the stair flagged as inverted?
I have had some issues when that error/warning has popped up.
AC24 / AC26 / AC27
Win10
Martin Jules
Mentor
Yes, the text is part of the stair. E.B., in French, stands for "down" in English, and E.H. stands for "up"., which makes the case even more difficult to understand. This is the first time I've faced such a situation. I'll look further into it.
Martin Luther Jules
AC 10-29 (Full)
Martin Jules
Mentor
Great idea. I'll check into it.
Martin Luther Jules
AC 10-29 (Full)
Martin Jules
Mentor
Not even that. It displayed correctly in the View Map but was missing from the layout.
Martin Luther Jules
AC 10-29 (Full)
