Structural drawing in archicad is my target.
I started making the general drawings (the formworks) for RC structures.
It's easy.
Now I'm working to produce some gdl object for the rebars.
I thought a lot about this argument ... and I think that the most difficult part is the drawings of the beams because they depends on several aspects (the way you calculate, the way they build the beams, the way they build the rebars cages, etc). Moreover the cases are so much that you cannot cover all of them with one object only.
Moreover the 2D drawings are of course easier (and more useful in my opionion) that the 3D model of the rebars (except for very complicated nodes of reinforcements).
Actually I'm working on a structural project with archicad of course and for pillars and beams I will be put in my layout the drawings created automatically by the structural software (here in Italy there are very good structural software which produce very detailed drawings for rebars)... all the plates, the retaining wall will be detailed into archicad (with some objects created for the scope) ...
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
