Surfaces / CINEWARE SETTINGS
ryan
Hi there.
Trying to make a custom surface and as you can see adjustments are not showing up.  When i first launch Archicad 25 custom surface adjustments are visible  but when I go back into custom surface to fine tune custom surface adjustments do not  show up.  I've also opened existing program surfaces and adjustment don't show up.
Any help would be appreciated
6 REPLIES 6
Lingwisyer
Guru
Can you expand the Color category on the left side?
ryejuan
maybe be a bug? have you tried restarting your Archicad?
In the end what is your Objective?
ArchiCAD 9 onwards
This sounds a bit strange but try updating your graphics card drivers.
I am sure I have seen it before where the surface settings were not visible and that fixed it.
Also it helps to now what language version and build of Archicad you are using and your operating system and machine specs.
It is handy to add this to your signature.
YOU ARE AWESOME!  Much appreciated!
Thanks for your help.  I updated graphic card but didn't solve issue.  Issue was resolved when i followed direction to expand color category on the left.
I believe you can also click on the icon just to the right of the Color option in the main dialogue to go to the relevant page.
Ling.
