Text Editor Formatting Options
rob2218
this is a disaster.........how can I make the "text box" formatting actually be a "box-typed" format?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
8 REPLIES 8
Not quite sure what you want.
You have chosen left and right justification which is what Archicad has done.
Everything is justified to the left and those lines of text with spaces have justified to the right as well.
The last two lines of text have no spaces so can't justify to the right.
If you are wanting the text equally stretched across the text box (i.e. between all characters and not just spaces between words) then this is not possible.
Just playing with this (in 19 at least) and it seems the very last line never justifies both left and right even if it is words with spaces.
Other lines will not justify both either if you use carriage returns.
David Maudlin
Rob:
Maybe a difference between Mac and PC. I get both between-word spacing and between-letter spacing when switching to Justified. You are getting only between-word spacing. In your example, the line "combustion gas" will get very hard to read if the between-letter spacing is implemented.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David that is interesting about the letter spacing on Mac.
But I see the first line is not justified because of the carriage return and the last line is not justified either.
This seems like a bug to me as I can't think why these should not be justified the same as the rest of the text.
Stress Co_
Sort of works for me (MacOS 10.9)
Adjusting the size of the label helps to fine tune.
Marc Corney, Architect
Red Canoe Architecture, P. A.
David Maudlin
The justification is only for full lines of text (no carriage return). This makes sense, for example, what if the last line was just the word "cut"? The "c" would be on the left, the "u" in the middle, and the "t" on the right, rendering the word unreadable. A word processing application, like Word, works the same way.
Understandable for a single word but what if there are multiple words.
Certainly on the last line in my example shouldn't that be justified - there is no carriage return there.
David Maudlin
That is not the common solution for the last line, normally only full lines of text are justified. Look at any newspaper column, contract documents or how Microsoft Word handles justified text. In this Wiki article it states that "justify is equal to left justify" unless the application has other options, which is rare.
