2024-09-19 09:55 PM - last edited on 2024-09-20 03:31 PM by Laszlo Nagy
is there a way to select 2 points in order to place text at an angle while using the "text tool". or do i need to place the text then rotate? hope the latter is not the solution.
Operating system used: Mac Intel-based Sonoma 14.5
Solved! Go to Solution.
2024-09-20 01:19 PM
BTW this is a good wish.
another Moderator
2024-09-20 01:49 AM
AFAIK there is no option though you could rotate the view prior to placing if there are more than one since Text will stay horizontal to the monitor.
another Moderator
2024-09-20 02:30 AM
Or if you know the angle you can just set the angle setting before you place it.
2024-09-20 11:52 AM
The angle is also syringe-able, by the way.
Or just set it before hand, like Barry suggests.
2024-09-20 01:19 PM
another Moderator
2024-09-20 01:53 PM
best answer @Eduardo Rolon IMO. and pretty silly not to have when even a drafting board can do it? and i am that old 😎
