Text Tool Rotation
Zdenko
is there a way to select 2 points in order to place text at an angle while using the "text tool". or do i need to place the text then rotate? hope the latter is not the solution.
Operating system used: Mac Intel-based Sonoma 14.5
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
Eduardo Rolon
BTW this is a good wish.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
5 REPLIES 5
Eduardo Rolon
AFAIK there is no option though you could rotate the view prior to placing if there are more than one since Text will stay horizontal to the monitor.
AC29 US/INT -> AC08
another Moderator
Or if you know the angle you can just set the angle setting before you place it.
runxel
Hero
The angle is also syringe-able, by the way.
Or just set it before hand, like Barry suggests.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
Zdenko
best answer @Eduardo Rolon IMO. and pretty silly not to have when even a drafting board can do it? and i am that old šŸ˜Ž
Sequoia 15.1.1
Setup info provided by author
