‎2017-11-14
11:37 AM
‎2024-04-04
03:26 PM
‎2017-11-14 11:50 AM
‎2017-11-14 04:26 PM
‎2017-11-14 09:34 PM
alemanda wrote:I had archicad 20 and i didn't have any problems. Only after upgrading to 21. Any ideas?
I think it depends on the operating system.
I had the same issue when I was under Win7. After upgrading to win 10 the issue disappeared.
‎2017-11-14 11:25 PM
‎2017-11-20 01:01 PM
‎2017-11-20 03:36 PM
dkovacs wrote:I don't understand why you don't maket it for windows 7 to work. I don't want to buy windows 10, i have license for windows 7 and if i paid for archicad 21 why would i not use it. If there is windows 10 then people shouldn't use windows 7 anymore?
Hello Guys,
It looks a lot like a known issue in ARCHICAD 21. It is mainly caused by people turning on the "override High DPI scaling behavior" on Windows 10 (which is not supported by ARCHICAD), but it also happens on Windows 7 in general (as it is not supported/tested by us anymore).
In general, on Windows 10 this shouldn't be a problem, and with ARCHICAD 20 this is not a problem on Windows 7 either. This is only a display issue (published drawings should be fine), so you can:
- disregard the display glitch
- upgrade your OS to Windows 10
- or downgrade to ARCHICAD 20
Kind Regards,
‎2023-04-20 09:43 AM - edited ‎2023-04-20 09:44 AM
Hey daniel,
Today ive been having issues with this also, except i currently am running Archicad 26, on windows 10. Ive toggled various DPI scaling settings, with no solution, ive also followed the DPI scaling issues listed within the link attached, with also no result. As it is limited to Archicad 26, there is limited information available.
Any help is greatly appreciated, kind regards samuel h
‎2023-04-20 09:53 AM
Is this an old file created in an earlier version that you have now opened in version 26?
If so there is a known bug where the text moves (dependent on the font, some fonts are worse than others).
However, it has been fixed with the latest update (5002).
Do not try to adjust the text.
Install the latest update and then open the file again and see if it and better.
If you do fix it up in 26 (I believe you can fix it by resizing the text) and then apply the latest update, it will appear wrong again and you will need to re-adjust the text to fix again.
‎2023-04-20 11:40 PM
Hey barry thanks for the reply,
The file is the office template file, which has been brought forward each year, dating back to god knows (its terrifying i know) alas i am in the process of rebuilding in 26, just behind.
I do however have the latest update installed, so sadly that must not be a fix for this particular issue.
