Trimming roofs
dhnguyen
I have a shed dormer that is on top of the main roof. I can't figure out how to trim the main roof so that it doesn't show up in the section. Please see attached images. Thanks
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Lingwisyer
Guru
In plan, select the large roof, then Subtract the relevant area from it?
David Maudlin
DNguyen:
I would model this the way it will be built: cut a hole in the main roof to the exterior faces of the shed dormer walls.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
dhnguyen
Awesome, thanks. I was able to get it to work!
DNguyen
ArchiCAD 18- 25
